MG 2525 Scanning Output size
progman
Initially the output size in ScanGear Advanced tab was set to letter size 8.69" x 11.??",  but afterwards it auto changed to
8.34" x 8.64,"  resulting in cropped preview image!!
I've tried numerous hacks but can't change it back!!
Please help.
Hi progman,
Once you are in the Advanced mode of Scangear, click the 1st button in the upper let corner.  That is thumbnail view.  Once that is off, you should be able to select your output size.
https://ij.manual.canon/ij/webmanual/ScanGear/W/MFP/20.0/EN/SG/Sg-PAGE3.html
3 REPLIES 3
progman
A newbie error, apologies.
Windows 10 Home, USB connected...thanks
Hi progman,
UGH, I knew it was an easy fix!!  Thanks a lot!
