MF210 is a PITA
swbouton
Unfortunately, I have TWO MF210's.  Both give me the same problems:  (1.)  Thy go into a COMA, not just going to sleep.  The only way I can "wake" them is to pull and reconnect power.  It's worse than an annoyance since they essentially have to have power cycled in order to print, and  (2.) after I applied the latest updates to one of them, "MF210MFDriverV2120W64ukEN.exe", the scanner on that machine takes about 10 full minutes to create a one-page PDF if it suceeds at all.  Sometimes it times out after waiting about 8-9 minutes.
Does anyone have a suggestion other than replacing them with a Brother or an HP?
0 REPLIES 0
