10-11-2019 09:33 PM
IJ Scan Utility 2.3.4 doesn't work properly for Mac OS Catalina. The first page of a document is correctly scanned, but scanning the second page yields the error message "Failed to open a session on the device" No driver is listed, for Canon MG3220. When can we expect a working driver for this OS?
11-10-2019 03:54 PM - edited 11-10-2019 03:56 PM
I have the same problem with a Lide220 Scanner and this worked so it may work for you.
11-10-2019 06:59 PM
05-21-2020 01:18 AM
still nothing?
rco
11-07-2019 12:37 PM - edited 11-07-2019 12:39 PM
I have this exact same problem for the IJ Scan utility using my MG5520. I've downloaded all of the latest print & scan drivers and the latest scan utility ... and applied all of the latest MacOS updates for MacOS Catalina 10.15.1.
11-07-2019 12:45 PM
The November 1, 2019 scan utility update does not fix the problem. PDF scans only one page and then fails to scan a second page.
01-29-2020 12:10 PM
02-06-2020 04:46 PM
Hi, where can I find the latest version which fixes scanning and printing issues with mac os catalina? My canon is mx925
11-10-2019 06:59 PM
11-24-2019 09:29 AM
01-23-2020 08:38 PM - edited 01-23-2020 08:42 PM
Totally worked for Pixma MG5520 with Mac OS Catalina !!! First I tried updating from Canon but new November 2019 software didn't fix the problem. Then I found this solution. Downloaded the UK utility and now I can easily scan multiple page documents. Thanks
02-27-2020 12:45 PM
@Duke1 wrote:I have the same problem with a Lide220 Scanner and this worked so it may work for you.
This worked beautifully for my Pixma MG7720, after spending all morning trying to access support (couldn't) and downloading drivers and software. Thanks!
