I need help please to convert my .cld files to .el8 format
Pollin
HI
I upgraded my computer and now I cannot access my .cld files to print as Easy Print for the new printer MX5460 seems to use .el8 files.
Can I please get help regarding how I can convert my files to the new format?  Thanks.
Pollin
1 REPLY 1
Chely
I had the same problem. I found that you can download a stand alone version of CD Labelprint from http://cd-labelprint.software.informer.com/ . It runs fine on my Windows 10 pro 64 bit. Does not convert to el8 but enables you to print cld files. In addition, if you right click text box in cld file and select 'properties' you can highlight and copy text etc and you should then be able to paste into the new version of labelprint if you want to create a el8 file.
Hope this helps.
