11-26-2012 11:01 AM
Is there a fix for a canon pixma 620 that is giving me an error message 620. I reset the printer -- unplugged for 10+ minutes. That didn't work. Then took the print head out and cleaned and dried it. Replaced it .....that didn't work. Is there a home fix for this. If not I will be in the market for a good all in one printer...scanner etc. Any suggestions. Thanks glwun
07-06-2013 07:55 AM
I have tried everything that you suggest. is there anything else I can do to get rid of the B200 error
Any suggestions gratefully received.
thanks.
sally2
07-06-2013 09:58 AM
You might try tips and solutions given in this article and comments:
07-26-2013 02:17 PM
from jim5751. I followed the steps listed to solve errprb200. When I had the print head out, I noticed it had black ink on the bottom of the print head so I wiped it off with a tissue and re-installed it into the printer. I reloaded the tanks turned off the printer etc. when I turned it back on I now have an error message that says
" UO52 "this type of print head is incorrect. Install the correct print head."
is it possible that that I changed the electrical ID for the print by wiping it off with a tissue. Is there any thing I can do to reverse this problem?
07-26-2013 03:18 PM
08-15-2013 09:22 PM
09-21-2013 12:20 PM
Hello,
I know the last reply is a month old, but I have to say this, because this site is the first hit you find on the keywords: "Canon mp620 B200 error" and I have the solution!
My solution was VERY simple, but I don't know if it works by other printers.
Solution:
It worked for me! I don't know if it works by other printers!
Sorry for my bad English, I'am 15 and writing English is not my best point.
I hope it works for you too.
JelmerM
09-22-2013 06:09 PM
09-22-2013 06:26 PM
10-09-2013 08:50 AM
03-12-2014 01:10 PM
