How to connect PIXMA TS3722 AT&T air Wi-Fi.
lemontree
hi I am having trouble trying to hook up my new printer TS3722 Canon to my AT&T air router modem I’ve tried numerous times and just seemed to be caught in the loop of not being able to accomplish it and would appreciate any input and help plus assistance that I would be able to find here
1 REPLY 1
DerrickL
The TS3722 requires a 2.4 ghz signal to operate, AT&T air routers should have that signal but it may need to be enabled. You do not need that signal if you use a printer cable to connect your TS3722. This step by step guide should help you to determine if your network has 2.4ghz and  it will guide usb connection as well. It will require a software download and a printer cable to set up wireless connection  unless your router uses a WPS push button.
https://ij.manual.canon/ij/webmanual/WebGS/WGS2/wgs_select.html?lng=en&type=setup&area=us&mdl=TS3722...
