How does one print using a usb cable on the mg6420?
Maryk999
My Internet connection is down...need to print for new employment!  I'm using a MacBook Pro.
1 REPLY 1
merrymary247
Rising Star
As long as you already installed the drivers, when you plug in the USB cable it should automatically add a USB instance of the printer into system preferences (so, if you had the wireless version installed before, you would have 2 options now, MG6400 series and MG6400 series copy 1, or something similar). As long as you select the new instance of the printer you should be able to print via USB fine.
