07-22-2024
04:06 PM
08:41 AM
I run an office and just bought 5 Canon Pixma g5000 series printers and they all are in different peoples' offices. When you go to print, all 5 printers pop up as Canon g5000 series so it's very confusing to try and print to the correct printer. I looked through the manual and couldn't find anything helpful. Any tips?
07-22-2024 06:19 PM - edited 07-22-2024 06:24 PM
Reserving or assigning a static IP address is done on your router. After a device has been connected, you can review the list of attached devices. Once you have the IP address the router has assigned, you visit the LAN settings. There is typically a place to assign or reserve IP's there.
Once you have the IP of the device, open a web browser and enter is there. Example, my printers IP is 192.168.1.99.
Log into the printer's webserver and visit its network configuration settings. The host and mDNS names are there.
This changes its broadcast name on the network, which is what you want. Not the computer.
07-22-2024 04:19 PM
Hi there!
So everyone's on the same page, what are the exact models of your printers, and what operating system(s) do you use?
Have you installed the Canon software & drivers on the client computers from https://canon.us/ijstart
07-22-2024 04:26 PM
Looks like they are all G5020, and yes I have.
07-22-2024 04:27 PM
Also we all use iMac's
07-22-2024 04:52 PM - edited 07-22-2024 05:09 PM
How about logging into the printer's web server and changing the hostmame or mDNS name?
I would also assign each printer a static IP on my network and add them to my MACs as IP printers.
07-22-2024 04:53 PM
Do you have any idea how I would do that from an iMac? Not very tech savvy.
07-22-2024 05:20 PM
Do you know how I would go about logging into the printer's web server? Is that where I would also assign them a static IP?
07-22-2024 05:33 PM - edited 07-22-2024 05:34 PM
When you installed the printers, was there not a place where you named them, other than the default name?
You could uninstall them, then reinstall them, naming them as you wish.
07-22-2024 05:57 PM
We set up all the printers manually on the printers themselves. Afterwards is when we went through the install process. On my computer I was able to rename them, but when I go to print from my phone it just pops up as default.
