Help! Selphy 900 and Windows 8
2GenMom
I just bought a new computer that runs Windows 8 and it appears my Canon Selphy 900 is not compatible.  I've searched for drivers to no avail.  Can anyone help????  Thanks!
2 REPLIES 2
Julius
Rising Star
Hi 2GenMom,
Currently, the SELPHY CP Series Printers are not supported in Windows 8. This is partly because of certain development specifications required by the operating system. Though this printer is not supported for printing from a Windows 8 computer, you still have options for printing your photos.
You can print your images stored on a memory card by inserting the memory card into the card slot on the printer and selecting the images to be printed.  Once selected, press the PRINT button to start printing.
Another option is to print directly from a digital camera that supports the PictBridge standard.  This method requires that you connect your digital camera directly to the printer using a PictBridge USB cable (usually provided with the digital camera and not with the printer).  Once connected, you would print to the printer using the controls on the PictBridge compatible digital camera.  To verify if your digital camera supports the PictBridge standard, please refer to the documentation that came with your digital camera.
While I am disappointed to hear that I can't use the printer through my new laptop I do appreciate your alternative ideas.  Thank you so much for your response!
