12-01-2020 10:39 PM
All colors have worked beautifully since installing. Suddenly, yellow has stopped working. Tank is half full. Clean and Deep Clean has been done multiple times. No change. Removed the color print head and can see a yellow liguid bubble at the nozzle which would seem to indicate the tube is not clogged. Before trying Flush was wondering if the problem could be with the color print head?
12-18-2020 03:50 PM
Hi danomer,
Please perform an ink flush to resolve this issue:
https://ij.manual.canon/ij/webmanual/Manual/All/G6000%20series/EN/NTR/ntr_h_01.html
If you continue to have difficulties, please contact our support group using the following link:
https://mycanon.usa.canon.com
10-30-2021 08:51 PM
So, only buy this printer if you want to buy a whole **bleep** new tank at the same frequency you used to have to buy a little overpriced cartidge Great selling point.
Yellow not working, so I did cleaning and deep cleaning (all tanks are nearly full.)
After deep cleaning, now cyan is not working either.
OK, will flush, wil buy all new ink, but I hate you.
This is by the way not at all eco friendly.
10-30-2021 08:54 PM
(To clarify, I do not hate OP, I hate Canon.)
10-30-2021 09:08 PM
Oh by the way the satisfaction survey won't let me say I'm dissatisfied (I did not even swear.)
10-31-2021 10:59 AM
The exact same thing just happened to me. Yellow went missing first, and followed by cyan after deep cleaning. Doesn't seem like the individual nozzles got clogged as the check pattern is completely blank for those colors. Just curious, does ink flusing work for you?
11-26-2021 08:12 PM - edited 11-26-2021 08:17 PM
I had missing cyan and flushing worked - for now.
I got my printer in March 2021. The problem occurred halfway through the first ream of paper I used. I only noticed the missing color last week.
Watching the "flushing" I first thought that maybe it was doing one color at a time, because the level of th yellow droppd faster during th first 2 cycles, the magenta just a little and the cyan just showed a few bubbles.
The cyan level didn't drop to match the magenta level until the 5th cycle.
They aren't kidding when they say it uses a lot of ink. My estimate is that wastes a third of each tank, enough to print ~2500 pages . if this happens again I'm going to be very disturbed by the performance of this prrinter. The s530 and mx922 I had previously worked fine for years with aftermarket ink.
In case this was due to my selecting BW draft printing for the past month, I'm going to "waste" ink by doing all printing in "normal color mode and print a test sheet every week.
11-27-2021 08:52 AM
11-27-2021 09:54 AM - edited 11-27-2021 09:55 AM
I'm setting up a recurring Google Calendar event to remind me every week to print a test sheet, with a link in the description to the test sheet I've created.
I don't think it's fair to blame Canon for what happens when an ink tank runs dry, because every inkjet printer including the old 300 dpi models had the same characteristic.
IMO, every inkjet printer advertised to normal consumers rather than businesses should have an built in maintenance option to automatically print a test sheet if it hasn't been used for 4 days.
I do believe it's fair to blame Canon for not including a warning about refilling the tanks and that you can do it before they run dry.
The manual they have online makes a big deal about that:
Note
Color ink may be consumed even when printing a black-and-white document or when black-and-white printing is specified. Every ink is also consumed in the standard cleaning and deep cleaning of the print head, which may be necessary to maintain the performance of the printer.
When ink runs low, promptly refill it.
https://ij.manual.canon/ij/webmanual/Manual/All/G6000%20series/EN/UG/ug-127.html
PDF manuals for the Canin G6020 are at: https://bit.ly/312nkX5 (the forum sw wouldn't accept the full ink as valid)
11-27-2021 11:47 AM
