Error Code 5 156 69
bmijgoodrich
The scanner is not working. I keep getting an error saying that the Scanner is turned off and the USB is disconnected. Neither are true. The printing function works and it's connected by a USB cable. I've tried multiple USB ports, I've deleted extra folders in the TWAIN_32 folder besides the MX390 Series folder. and the wiatwain.ds file. I am running Windows 7. Thanks for any suggestions.
38 REPLIES 38
I have this problem too and it's recurrent.
Yesterday I spent 40 minutes on the phone with Canon - they got me to turn the printer off and on then off and on, press the black button to do a test copy, and so fourth..
he got it scanning again, but if I unplug the printer to put it away, and get it out to use it again, the same problem happens again
so today I turned the laptop on and brought the laptop into the room I'm working in and it's happening again 😞
NOT WORKING SAME ERROR
LadyBev59
I am using PIXMA MX-452 on windows 10, i've updated the drivers and still getting the same error code.  HELP
Hi LadyBev59,
The 5,156,69 error can be caused by security software that is enabled on your computer.
Do you have Norton, McAfee or Webroot installed on your computer?
no i have TotalAV
Please try disabling that software and then attempting to scan again.
I'm having this problem as well - Pixma MG5750, running Win 10 with Avast antivirus running. I disabled Avast temporarily basd on advice in this post and had no results. Printing is fine, it's purely scanning which is one of the main reasons I bought this model. I even went and hunted up the USB cable and plugged that in. Still unable to scan. Please help?
N6700
Thanks Fodder 5.Your post reallyhelped me
My operating system is Windows 10.
Using Control panel I deleted all the Canon Printer.
Then plugged the printer into the mains and connected USB to Laptop.
I have the same problem i need help , i have windows 10 , is this cause because of lack of ink?
No, my ink is full.  I can't seem to get an answer as to why this is happening.
Friends and Family
