11-25-2019 07:37 AM - edited 11-25-2019 07:56 AM
i'm trying to print some coloured images, but the colours seem to be mixed up. See images below
This is how the image looks lie out of the printer (canon MG4250):
and this is how it should look like:
When i print out the nozzle check it looks like this:
Does someone knows what's wrong and how I can fix it.
This all started when I placed a new colour cartrigde in the printer
Thanks
11-25-2019 08:07 AM
The following questions come to mind.
Did you install Canon branded inks?
Are you sure you inserted the correct color into the correct slot?
Nozzle check pattern;
Print head alignment looks OK
Then, the colors looks ok on one side, but completely off on the other. The Cyan looks like its having a little bit of an issue.
