02-14-2024 12:42 AM
One color was not printing after repeated nozzle cleanings, so I purchased and installed a new genuine Canon print head type QY6-0086. Now there is no color printing at all, only black. More nozzle cleanings had no effect. When printing a nozzle check page, the black test matrix prints fine. Then the printer scrolls quickly to the bottom of the page and doesn't even try to print the color rows. Help.
02-27-2024 01:00 PM
If 1 cleaning and 2 deep cleanings did not resolve the issue, your MX922 would require service.
If the printer is in it's 1 year warranty, I recommend reaching out to Canon support for your warranty options. You will need to register your Canon gear HERE to access additional support options.
If the printer is out of warranty, you would qualify for the Canon Upgrade program. This is for out of warranty units which have been diagnosed to require service or are incompatible with a new or upgraded system. This program allows you the opportunity to purchase a replacement product discounted from the list price. Free ground shipping is included with your purchase.
If you would like to take advantage of this offer, please call our Sales Department at (866) 443-8002 Mon-Sat, 9 AM to 9pm EST excluding holidays.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well
03-29-2026 06:59 PM
My original MX922 print problem was that the PGBK black and white printhead started to print smudged characters with shadows such that printing was illegible on certain lines and QR code spots were smudged/smeared so badly that they were unreadable.
I too just had the identical problem after buying a new "genuine" Canon QY6-0086 and the PGBK printed perfectly but none of the colors printed on the nozzle check pattern. I too tried the internet recommended printer cleaning and deep cleaning cycles to no avail. FRUSTRATING! However what worked was the printhead nozzle cleaning procedures described in many Youtube videos. I previously purchased a printhead cleaning kit with cleaning solution, syringe and various tips for the syringe which I used when ink dried in nozzles and required serious cleaning. Since my bottle of cleaning solution was used up, I made up a solution that I've been successful with for cleaning plugged heads, 4 oz distilled water, ~10% blue windex (contains ammonia), ~20% isopropyl alcohol and warmed ~30 seconds in a microwave. I removed the new print head and placed it in a plastic container on top of a folded paper towel at the bottom. I placed a tubing on the syringe that had approx ID of the color connections that the ink cartridges mate with. With ~4oz of cleaning solution in the syringe, I placed the tubing tip firmly on top of each color connection and squeezed the solution through the printhead. You will see the solution coloring the paper towel under the printhead. After doing this the first time for all the 4 small connections that weren't printing, I gently wiped the printhead and reinstalled the printhead and the cartridges, I printed a nozzle print check and knew I was on the right track because the magenta printed OK but I still had nothing from the cyan, yellow or small black cartridge. I again removed the new printhead and repeated the above same cleaning sequence three times on the three remaining colors that didn't print. I also left the printhead to soak on top of the paper towel for 2 hours. Upon wiping and replacing the printhead back into the printer and performing a printer "maintenance" clean, I again did a nozzle check pattern. SUCCESS!! The nozzle check pattern printed all colors perfectly!
I'm not sure why a new, genuine Canon printhead would require severe cleaning in order to get the small cartridge colors to print while the PGBK big black cartridge printed fine, but it worked for me and I have my MX922 printing like new again instead of having to go out and buy another printer.
