09-20-2020 10:38 AM
09-20-2020 10:47 AM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know what model Canon
equipment you are using. Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
09-20-2020 10:49 AM
09-20-2020 10:52 AM
10-13-2020 04:23 PM
Hi Guytensei,
The files are grayed out because they are in a format that the app does not recognize.
You do not have to use the app to print those files.
Please close the app and then open the file that you wish to print (not using the app). Once that document it open, please tap the or
and then tap Print. In the Print window, tap "Select printer", select the Canon MX920 series and then Print. Your document will print.
If you are using an Android device, you can print those documents after the "Canon Print Service" is installed on your Android device. For more information regarding Canon Print Service, please use the following link:
https://play.google.com/store/apps/details?id=jp.co.canon.android.printservice.plugin&hl=en_US&gl=US
