11-06-2012 01:11 AM
Hello
My canon mx318 front door error, current position opended.
I tried to close then opened but still error, i tried to pickup a little bit run in seconds then error again.
lap by hand at right side also cant solve, please advise
thanks
11-08-2012 08:43 PM
Hi LPI,
To try and resolve the issue, please ensure that the printer is laying on a flat surface with nothing underneath it, and that the paper output tray has room to fully extend. You will also want to ensure that the Paper Thickness Lever is set to the left side if you are printing on any other type of paper other than envelopes or T-Shirt transfers; if printing on envelopes or T-Shirt transfers, you will want to have the Paper Thickness Lever set to the right side. Hope this helps!
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
