02-23-2021 04:18 AM
03-02-2021 06:10 PM
02-23-2021 10:27 AM - edited 02-23-2021 10:34 AM
" I used to be able to print and scan from my MacBook.. - Running which Mac OS?
How are these devices connected?
"Since then".. - Did something change? Did you upgrade the OS? If yes to what version?
See this article:
Canon Knowledge Base - Error -9923 Appears When Trying to Scan Across a Network on macOS
Note, if you are running the latest version of MAC OS (currently Big Sur), and you have upgraded your OS running a drivers package for an earlier Mac OS version, you might get unexpected results.
First try disabling IPv6 (in the article I referenced above) Restart and test.
If that doesn't solve, Remove the device from Printers and Scanner dialog, and reinstall using the appropriate drivers package for the version of MAC OS you are running. Note again, if the TS5120 is your only installed printer "Resetting Your Printing System" might not be a bad idea. If you are now running BS, try installing the IJ networking Utility Lite.
IJ Scan Utility Lite is the application software which enables you to scan photos and documents using AirPrint. You can easily scan such items simply by clicking the icon you want to choose in the main screen of IJ Scan Utility Lite.
You should be able to print and scan using airprint under BS, no CUPS driver is currently avaialble. Please post the miissing information above, the steps you performed and outcome. We can try to assist further if needed.
03-02-2021 06:10 PM
