08-21-2020
06:20 PM
09:50 AM
It was when I first started using it as it is a used printer I just acquired, but then it started struggling asking for paper when it is already present so I tried cleaning the rubber rollers and even tried some double sided tape(on paper where the rollers contact) but to no avail. I'm using a stack of paper in the tray to. What is the fix and problem here? Thanks
[link replaced with image found at that link]
08-22-2020 09:46 AM
Did it ever work trouble free? About the only thng I could suggest is inspecting and cleaning the paper feed mechanism (which it sounds like you have done for the most part). Have you tried a different brand of paper?
Pitfall. Like used cars, this is what can happen when you buy a used printer. Someone apprently got tired of the feeding issue and now their issue is likely yours.
If there is nothing obvious, broken or jammed, and the mechanism is clean and moving freely, service or replacement are you best options.
08-29-2020 03:28 PM
