03-16-2022 12:49 PM
I changed routers. Now its a dual modem. I have it set to where I am using the 2.4ghz.
I am working on a widows pc. I was unable to print. So I uninstalled everything and tried to reinstall everything back. The setup goes through the whole process. If finds my printer but at the end it says failure to install MP drivers. I've tried installing the MP drivers and it installed but still no luck on getting my printer to print. Any help would be greatly appreciated.
03-28-2022 03:09 PM
Hi Nonniemonnie74,
Reinstalling will resolve this issue. To do this, please follow these steps:
1. Press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run window, please type CONTROL PANEL and click OK.
3. Click on View devices and printers (or Devices and printers, depending on your view).
4. Right click the Canon G3000 series and left click on Remove device. Repeat until all G3000's are removed.
5. Click Close to close that window.
6. In the upper left corner, click on Control Panel (or the Back button).
7. In Control Panel, click on Uninstall a program (or Programs and features, depending on your view).
8. Click once on "Canon G3000 series MP Drivers" and then click Uninstall at the top.
9. Follow the on screen prompts to uninstall the driver. When you click Complete, the driver is uninstalled.
10. Once done, please reboot your computer.
When your computer restarts, we will reinstall:
1. Please use the following link:
2. Click the Select button next to "G3000 series MP Drivers Ver.1.02 (Windows)".
3. Click the Download button. The drivers will download.
4. Once the download is complete, open your downloads folder. To access this, press CTRL and J, then let both go.
5. Double click "mp68-win-g3000-1_02-ea34_2.exe" to begin the installation.
6. Follow the on screen prompts to reinstall.
Once the installation has completed, please attempt to print.
