Canon PIXMA MX922 printer won't allow 2-sided printing of Word documents
LonnieC
I just installed a new Canon PIXMA MX922 printer to replace an older MX882.  Everything works well, and I am able to two-side print documents from web pages and e-mail by checking the "two-sided" box on the Print drop down menu..  However, I am unable to two-side print any Word documents.  No "two-sided" check off box drops down, and no "duplex" option is available, as it was with the MX882.  I never had this problem with the older MX882.  Can you help?
Thanks very much.
22 REPLIES 22
agdipasca
I am choosing two-sided printing on my print screen but keep getting one-sided printing from the printer....  please help!
agdipasca,
If you continue to have difficulties after reviewing the information on this thread, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
Here's how I have found that I can print two-sided on my PIXMAMX922:
1.  With your Word document on the screen, click on "File" at the very top left of the screen.  A small dropdown will appear.  Then click on "Print" near the bottom of that dropdown.  A new "Print" dropdown will show.
2.  Press on the Copies & Pages tab. A small window will drop down.
3.  Press on the Layout tab. Another window will appear.  Near the bottom of that window is a bar called "Two-Sided", which will show "Off".  This is what you're looking for.
4.  Press "Off".   Two options will appear: "Long-Edge binding", and "Short-Edge bindiing".
5.  Press Long-Edge binding. (You may want to try "Short-Edge binding" just to see how it does the two-sided printing.  I always use the Long-Edge binding.)
6.  Press "Print".  Your document will now print two-sided.
This sounds complicated, but in a few passes you'll find it can be done in just a few seconds.
By  the way, if you want to print all in black and white (and save your color ink), here's how you can do it:
Follow Steps 1 and 2 above.  On the Layout screen, press "Quality & Media".  On the bottom of the screen that shows, press "Greyscale Printing".  Then you can press "Print".  The printing will be in black & white.
You can do either or both (two-sided, greyscale) for your document before you press Print.
Good luck!!
How do I turn off two sided printing using a MAC IOS Sierra 10.12?
HOW did you fix the two sided printing?
When you select print the print window comes up and there's a selection to use double sided printing.
karendiamondmba
I tried this but it didn't help.
karendiamondmba
There is NO option to check.
Are you using the canon printer application or a generic application? Are you printing from a PDF file or Document such as word?
