01-27-2021 03:23 PM
My Canon PIXMA 6821 is printing blank pages.
I've cleaned the machine and the test pages are printing normally. I can copy documents perfect but documents either print blank or only 1-2 lines. I've tried printing both in color and black/white. I've also updated the drivers for my Mac and reset the settings on the printer.
What else can I try?
02-17-2021
02:08 PM
04:26 PM
Hi jaetown,
First, please print a nozzle check. To do this, please follow these steps:
1. Swipe the HOME screen of your printer and then tap the wrench and screwdriver icon.
2. Select Maintenance.
3. Select Print nozzle check pattern.
4. Select Yes.
Please compare your printout with the example below. If your printout is missing the black grid at the top or any of the color bars, please perform printhead cleanings:
3. Select Cleaning.
4. Select Yes to clean the printhead.
5. Select Yes to print another Nozzle Check.
If the nozzle check does not print correctly, please perform 2 or 3 more cleanings.
If the nozzle check still does not print correctly, your PIXMA MG6821 would require service. You are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
To help you get up and running quickly, we also offer free standard shipping (if the order is completed by 12:30PM ET). If you would like to take part in this option, please call our Sales Department at (866) 443-8002 weekdays and Saturdays after 11 AM ET (8 AM PT). Let them know you have been working with technical support and the Canon Upgrade Program was offered.
