01-19-2014 04:32 PM
Hello
I recently bought the Canon MG 5420 printer. I am wondering, I print mostly black documents as I am a student and don't use the color as much as the black. Will the printer still operate with just using the black cartige when I run out of the color. Also which of the black ink tanks are for black printing only in black, because there are 2 of them. Is it the big one or the smaller black one?
Let me know
02-14-2014 02:44 PM
Hello!
The printer is a full-color printer that requires all the ink tanks inserted for it to function. The reason for the two different black ink tanks are for the different type of printing each one can perform.
The larger black tank is a pigment based tank and is primarily used for standard black text printing or output.
The smaller black ink tank is dye based like the color inks, and is used for photo and graphics output.
You can adjust the quality setting to 'fast' in order to reduce the amount of ink that is used. This will help conserve the ink used from the large black tank with your normal print jobs.
Hope this helps!
05-20-2014 04:57 PM
