Canon G2000 Printer blinks 22 times
Aravind
   I have canon g2000 printer, which lamp blink 22 times, what i shoud do ? recently i replace scanner cable and pf sencor cable. I have a problem in scanner output which get black 2 inch line in middle of the scanner out put paper,so i decied to change scanner cable and pf sensor cable, now it blinks 22 times, when i contact with local and canon service , then asked to replace scanner unit.
  Pls reply what i do ?
Regards,
Aravind
2 REPLIES 2
If you have taken the printer apart or changed/modified any of its internal components (even a cable) it may not work correctly or as expected.
There is no information avaialble for the LED flashing 22 times;
Canon : PIXMA Manuals : G2000 series : An Error Occurs
Troubleshooting unknown errors:
Canon : PIXMA Manuals : G2000 series : Message Appears
Patrick
Hi Aravind,
The 22 flash error is an indication that your PIXMA G2000 series printer would requier service.  If you are in warranty, please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below:
https://mycanon.usa.canon.com
If your printer was purchased greater than a year ago, it is out of warranty.  You are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
To help you get up and running quickly, we also offer free standard shipping (if the order is completed by 12:30PM ET). If you would like to take part in this option, please call our Sales Department at (866) 443-8002.  They're available weekdays and Saturdays after 9 AM ET (6 AM PT). Let them know you have been working with technical support and the Canon Upgrade Program was offered.
