CD printing issue
Srmunro
Good day!
My Canon TS705 is showing error 1259 (Paper output tray on the front is not pulled out fully) even though I'm trying to print CDs!
As a reminder when you print CD´s, this paper output tray should be pulled in as it is written in every user manual.
And no, I'm not doing anything wrong because it worked once!
After that, when I tried to print more CDs using the same procedure, I got this error message. Is this a hardware problem, or can I fix it at home?
Thank you
3 REPLIES 3
DerrickL
Mentor
Mentor
support.usa.canon.com
https://support.usa.canon.com › kb › s › article › ART169524
Learn how to resolve error code 1259 on a PIXMA TS series printer.
Ecuse, did you read my post??
What has this to do with printing CD?
Stephen
Moderator
Moderator
Hi, Srmunro!
I can see how that would be a frustrating block in your workflow, especially since you’re following the manual exactly. This error usually points toward a physical hurdle with a sensor or a small obstruction.
Because your model is supported outside of the US, the best bet is to reach out to your local Canon team to have them take a look at the unit. You can find your regional contact info through the global portal here: https://canon.us/globalsupport
