01-25-2017 09:12 PM
I've been using an MX922 and My Image Garden for a couple of years to print onto CD's and DVD's with no problem. I updated my iMac to Sierra and couldn't print to discs anymore. I saw that Canon had updated the drivers for Sierra and installed those plus updated My Image Garden. Now when I try to print to CD the print dialog looks different and all I can choose from are different paper sizes. Disc is not a choice.
I've deleted the printer several times and reinstalled the drivers but get the same result. I remember something popped up about AirPrint and wonder if that has something to do with it. But I haven't found anything to turn AirPrint off.
Any suggestions? I print on discs for my clients and really don't like using a Sharpie for my labels.
01-26-2017 01:20 AM - edited 01-26-2017 01:21 AM
Hi AVGuy,
Would you be able to provide a screenshot of your My Image Garden main screen so we can see what you are seeing?
Should you need more immediate assistance, we ask that you please contact a Canon technical support representative at one of the methods provided here. A representative will be happy to assist you free of charge.
01-27-2017 09:41 AM
I was able to reinstall the Canon MX922 and this time did not select AirPrint. When I pull up my Disc label in My Image Garden everything looks as it always has.
When I click print, the print dialog looks different than it has in the past. I was able to dig down and create a preset with the paper size of 4.7" x 4.7", which is the size of the disc. I can then select the media type as printable disc and paper source as disc tray. I thought that would work. But when I print the text is sized too large and prints larger than the disc.
I've tried using the proper size several times but it seems to revert to a larger paper size.
01-27-2017 11:46 AM
Hello.
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
02-12-2018 05:16 AM
02-12-2018 04:20 PM
That was back awhile ago and I don't remember what I did to fix it. You can call Canon support and they should be able to help.
11-04-2018 11:09 AM
i un-checked airprint in the prefences for my image garden and now it works perfect. The correct print box came up with the dsic image option. Praise the Lord!! Took all day to figure this out.
11-04-2018 11:09 AM
02-12-2018 05:15 AM
11-04-2018 11:10 AM
