Black Ink Not Printing, TS6351a
jimson19
Hi everyone,
I’m having a strange issue with my Canon TS6351a printer and could use some help.
When I run a test print after a deep clean, everything looks perfect — all five color lines (including black) print correctly. However, when I try to print anything that uses black ink, it won’t print black at all?
Additional details:
  • There is plenty of ink left, recognized by printer, computer, and Android.
  • I’ve already tried two different original print heads.
  • The printer recognizes the ink cartridges with no errors.
  • The printer and computer diagnostics show no issues.
  • I’ve installed the latest drivers.
  • I’ve done multiple deep clean cycles.
  • I also performed a full printer reset.
Has anyone experienced this problem or knows what else I can try? I use normal paper...
Thanks in advance!
5 REPLIES 5
DerrickL
It is obviously not an empty black cartridge problem, so it must be a driver or settings issue:
 Review Your Printer Settings
Your software settings could be the hidden cause behind missing black ink. It’s worth reviewing them before assuming there’s a hardware problem.
Suggested fixes:
  • In your printer preferences, check if “Grayscale” or “Color Only” is selected.
  • Choose “Black and White” or “Monochrome” to prioritize black ink.
  • Update your Canon printer driver to the latest version available on Canon’s website.
Many users ask why Canon printer not printing black and are surprised to find the fix is as simple as changing a default print setting.
 Look at Paper Type and Quality Options
Canon printers adjust ink flow based on the selected paper type. If the wrong paper setting is chosen, it can affect how black ink is applied.
Try this:
  • Open print preferences and select the correct paper type, like “Plain Paper.”
  • Avoid selecting specialty papers like glossy or photo paper unless you’re using them, as these settings can limit black ink output.
jimson19
Thanks for the reply. I have already tried all the suggested steps. I updated the manual and installed the latest drivers directly from the official Canon website. I also checked the “print in grayscale” option but it didn’t make any difference. My settings are set to standard and the paper type is also selected as standard. Unfortunately the issue still persists.
DerrickL
Are they Canon ink cartridges? I have read here that sometimes a non Canon ink cartridge will print a Windows test page, but not from any Canon program.
jimson19
Yes, they are both genuine Canon ink cartridges.
Ron
Moderator
Moderator
Hi Jimeson19,
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market. The Canon TS6351a  isn't sold or supported by our team here at Canon USA.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to continue discussing Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
