08-05-2021 02:23 PM
How do I save my edited RAW files to a folder. I am using a MacBook Pro. Thanks
08-05-2021 03:50 PM
Welcome to the forum.
What software are you using?
Exactly what is the objective? Do you want to export the images in JPEG format for sharing or do you just want to have the edited image saved?
08-05-2021 04:07 PM
John
I am using DPP4, guess I should have stated that. I want to move my edited RAW photos to a folder without converting them to a JPEG. When I try to cut and paste the photo is the unedited version. The same thing happens when I covert to JPEG also.
08-05-2021 04:14 PM - edited 08-05-2021 04:17 PM
DPP saves the editing info with the RAW file when you save it.
I am away from my PC at this time, so I am going from memory.
I believe you can use the Save as option and select a destination folder as one method.
I also think you can just move the file to a different folder.
Perhaps you aren't saving the RAW file when you are finished editing? When you go to exit DPP it should ask you if you want to save the edited files.
08-05-2021 04:25 PM
I have been saving after finishing my edit.
I'll re-save and see if that will make a differnce.
To clarify when I edit and save DPP does not save it to the original file?
Appreciate the assistance.
08-05-2021 04:32 PM
08-05-2021 04:48 PM
When I click on the thumbnail the edited version will show as the bigger photo. If I click quick check the unedited version shows.
08-05-2021 04:52 PM
08-05-2021 05:01 PM
I updated the software and the edited files look great I just can't get them to save to a folder.
I took photos of my son's family and would like to put the RAW photos on a flash drive and give it to him.
08-05-2021 05:07 PM
