08-07-2023 02:31 PM
Since an upgrade to the ap the camera no longer connects. This is super important as I need to access high level roof photos remotely
08-07-2023 02:32 PM
I am now getting Err 11
08-07-2023 02:44 PM
Due to security enhancements, a firmware update will be required to continue to access the image.canon service. Learn more here: https://canon.us/43z0AbZ
08-07-2023 02:55 PM
Not sure how that helps. The SX740 HS is not on the lists needing a firmware update and my issue is with using The Canon Connect App, not the image Canon service.
08-07-2023 03:27 PM
Delete the connection info in the camera and the app. Then set up the connection again. See if that helps.
