09-05-2018 12:52 AM - edited 09-06-2018 02:32 AM
My camera battery was dead this morning for back to school pics so I grabbed my old 20D because it had a full battery, go figure, only to realize my relatively new computer does not have a slot for a compact flash memory card. Another option is to hook to USB BUT Canon does not have the driver on the website. Looking for anyone who has this camera and can email driver file...?
UPDATE. Super easy fix: Canon support replied and said "UPDATE Super easy fix: Canon support replied and said "The EOS 20D is no longer supported by the more recent operating systems in the normal communication mode. If you go into the EOS 20D menu you will find Communication under the wrench and hammer tab. Change this setting to PTP and you will be able to connect the camera to the Windows 10 computer and transfer images from the camera as if it were a USB card reader. Simply copy the image files from the DCIM folder to your Pictures folder on the computer (or folder of your choice)."
It worked.
09-05-2018 04:19 AM - edited 09-05-2018 04:31 AM
have you considered whipping out to your local drug store and getting a USB card reader. I am not aware that the USB connector needs a driver - it uses a standard protocol. However if there is some software required, by the time someone who has an EOS 20D one reads this, finds the solution, and answers this you could have sorted it.
09-05-2018 09:04 AM
Windows or Mac?
Which version of OS?
09-05-2018 10:31 AM
"Canon does not have the driver ..."
There is no driver. That's why there wasn't one. Windows should see the 20D. I have no idea if Mac will or not. They are weird. The suggestion of a card reader is your best choice and option.
09-05-2018 03:15 PM
Mac should see it, too.
