01-20-2021 12:19 PM
I have a Canon 7D Mark II and a Macbook running MacOS 10.15.7 running the 1.1 release of the EOS Webcam Utility. I have the camera setup as a webcam and works great except for one new behavior. If I'm in a meeting longer than 30 minutes, it'll shutoff almost exactly at 30 minutes for a couple seconds and then reconnect. It sounds like it is power cycling. In the Setting menu I already adjusted the Auto Power Off to disabled. When I had the beta webcam utility, this wasn't happening. Only really started noticing it after I updated it to 1.1.
Any thoughts on how to fix this?
02-04-2021 01:06 PM
05-04-2021 08:24 AM
11-22-2022 09:26 AM - edited 11-22-2022 09:27 AM
@bridgewrote:
Great question. I don’t have any idea why it worked. I guess I just got lucky.
If I had to venture a guess as to why it worked, then it would be because the default setting is not disabled. One minute might be the default, I’m not sure.
It is a safe bet that the Webcam Utility has to make a number of assumptions about camera settings. The best assumptions to make would be settings are at their factory defaults. The same app seems to be used with a wide variety of cameras, each with their own set of menus and options.
11-24-2022 12:19 PM
We can only guess at the logic flow chart where auto power off feature is turned off, but acts anyway. Auto power of 1 minute is taken as ignore power off. I wonder how many things were tried before guessing auto power off in 1 minute. Will Canon recognize this as a bug and fix it?
12-19-2023 01:03 PM
I solved the camera turning off issue but now the eos webcam utility is the one disconnecting from the camera but camera remains on... not sure whats going on
