11-26-2023 11:38 PM - edited 11-26-2023 11:39 PM
I'm attempting to use EOS Webcam Utility pro so that I can use a 600D as a webcam, but the webcam output never shows anything but the "EOS WEBCAM UTILTY" splash screen and the Webcam utility pro application itself does not load. Any assistant getting EOS webcam utility to function correctly or even better narrow down possible causes would be appreciated. I'm happy to forgo the application that EOS Webcam Utility Pro added and use only the webcam service that the older EOS Webcam Utility non-pro offered if that would work better, but it seems like the "Pro" version may be more actively supported?
Log Name: System
Source: Service Control Manager
Date: 11/26/2023 9:56:19 PM
Event ID: 7031
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: MyPC
Description:
The EWCService service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 0 milliseconds: Restart the service.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
<EventID Qualifiers="49152">7031</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2023-11-27T02:56:19.0605389Z" />
<EventRecordID>112965</EventRecordID>
<Correlation />
<Execution ProcessID="996" ThreadID="22952" />
<Channel>System</Channel>
<Computer>MyPC</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">EWCService</Data>
<Data Name="param2">1</Data>
<Data Name="param3">0</Data>
<Data Name="param4">1</Data>
<Data Name="param5">Restart the service</Data>
<Binary>45005700430053006500720076006900630065002E006500780065000000</Binary>
</EventData>
</Event>
Log Name: Application
Source: Application Error
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: MyPC
Description:
Faulting application name: EWCService.exe, version: 1.2.39.0, time stamp: 0x642db5d6
Faulting module name: EWCService.exe, version: 1.2.39.0, time stamp: 0x642db5d6
Exception code: 0xc000001d
Fault offset: 0x000000000004e5f4
Faulting process id: 0x6460
Faulting application start time: 0x01da20dd4bb197df
Faulting application path: C:\Program Files\Canon\EOS Webcam Utility Pro\EWCService.exe
Faulting module path: C:\Program Files\Canon\EOS Webcam Utility Pro\EWCService.exe
Report Id: 01308e36-12ce-4fc7-b93d-f658d0058c24
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2023-11-27T02:56:19.6726822Z" />
<EventRecordID>194527</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Security />
</System>
<EventData>
<Data>EWCService.exe</Data>
<Data>1.2.39.0</Data>
<Data>642db5d6</Data>
<Data>c000001d</Data>
<Data>000000000004e5f4</Data>
<Data>6460</Data>
<Data>01da20dd4bb197df</Data>
<Data>C:\Program Files\Canon\EOS Webcam Utility Pro\EWCService.exe</Data>
<Data>01308e36-12ce-4fc7-b93d-f658d0058c24</Data>
<Data>
</Data>
<Data>
</Data>
</EventData>
</Event>
Event ID: 1005
Level: Error
Keywords: Classic
User: N/A
Computer: MyPC
Description:
Windows cannot access the file for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program EWCService because of this error.
Program: EWCService
File:
The error value is listed in the Additional Data section.
User Action
1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
2. If the file still cannot be accessed and
- It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted.
- It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer.
3. Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER.
4. If the problem persists, restore the file from a backup copy.
5. Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance.
Additional Data
Error value: 00000000
Disk type: 0
Event Xml:
<System>
<EventID Qualifiers="49152">1005</EventID>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2023-11-27T02:56:19.6736803Z" />
<EventRecordID>194528</EventRecordID>
<Correlation />
<Security />
</System>
<EventData>
<Data>
</Data>
<Data>EWCService</Data>
<Data>00000000</Data>
<Data>0</Data>
</EventData>
</Event>
12-03-2023 10:03 AM
Basically the same issue. Here is what I have been told/read so far:
1. Contact Microsoft
2. You have a "home brew" system
3. It will not work with anything but Intel CPU's
4. It only work with "native" windows 10 or 11 and not on any upgraded systems.
My reply:
1. Microsoft has replied to other users about the EWC service issue and said it is Cannon that needs to fix an issue with the driver. More specifically the user needs an updated camera driver from Cannon.
2 and 4.I have tried installs on several systems and only one of them is a "home brew", the others came with Windows 10 pro or windows 11 Pro pre installed.
3.While one of the systems is running a multi core AMD the others are running Intel processors.
My conclusion: There is some sort of issue with the installer and/or the program. It works for some people, or many people depending on who is replying, therefore it is the user with the problem. I disagree with that assessment because the reply's do not fully help or fix the issue because I have issues across OS's and systems. If it was only the "home brew", OS upgraded, running AMD, system I could say "Oh...i see" but it isn't.
Do any of the reasons I gave above apply to your system?
