EOS Utility file naming: sequential counter from camera
zedagent
I love how flexible the file naming options are in EOS Utility when remote shooting. There's one thing I can't figure out though: how to insert the camera's sequential counter rather than EOS Utility's own counter.
If you choose not to modify the file name, you will get the same filename and counter that would be written to card if the camera were not tethered.
What I would love to see is the ability to modify the file name while retaining that same counter that the camera itself is generating.
The advantage to this is that if the tether accidentally becomes disconnected temporarily and you shoot some images to card, you can easily see where the gap in files are by looking at the counter in the file names.
Does that make sense? Any way to accomplish this?
jrhoffman75
You could customize your file naming command like this:
I haven't tried it, but the manula implies that the image number (which currently shows 0001) would be the file number from the camera.
2 REPLIES 2
Waddizzle
It is there.  Instead of renaming the file, you want to add a prefix.
jrhoffman75
