EOS Utility and Win 11
PamG1
Hello,
I’ve seen posts that EOS Utility doesn’t work with Win 11, correct? I’m so mad I upgraded and it’s past the 10 days that you can easily revert. Is there any other workaround? I have a 7D camera. Thanks!
5 REPLIES 5
jrhoffman75
I don't know if it works since I am on W10, but the Canon support site lists EOSU 3.16 as compatible with W11.
AMDphreak
I can get EOS Utility to launch on Win11, but the wifi tethering doesn't detect my camera.
Waddizzle
I recommend that you uninstall and reinstall the EOS Utility.  Do you need to use the EOSU 2 to use with the 7D?
Yes, EOSU2 is required for the 7D. The latest version of EOSU that will install both EOSU3 and EOSU2 is 3.13.20. It is available on the W10 support page for the 1D X Mark III (and maybe others) but not the W11 support page. Maybe it will work if you download the W10 version.
PamG1
Thank you all for the replies. I was able to reinstall W10 and reinstall my original EOS from disk. Phew!
