09-19-2017 03:30 AM - edited 09-19-2017 07:33 AM
On my Windows 10 Pro computer, EOS Utility 2 crashes on startup, regardless of camera connected or not.
It has been working without an incident for the past half year, but now this malfunctioning.
I have tried uninstalling completely and installing "EOS Utility" from my CD and then upgrading to "EOS Utility 2", but the same happens, EOS Utility 2 crashes.
Any suggestions to what I could do?
Edit: I have a Canon 1000D (EOS Kiss F / EOS Rebel XS) so EOS Utility 3 is not an option.
From eventlog:
- System
- Provider
[ Name] EOS Utility
- EventID 0
[ Qualifiers] 0
Level 3
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2017-09-19T07:20:25.672636100Z
EventRecordID 1590
Channel Application
Computer MaiaObs1
Security
- EventData
Configuration system failed to initialize at System.Configuration.ConfigurationManager.PrepareConfigSystem() at System.Configuration.ConfigurationManager.RefreshSection(String sectionName) at System.Configuration.ClientSettingsStore.ReadSettings(String sectionName, Boolean isUserScoped) at System.Configuration.LocalFileSettingsProvider.GetPropertyValues(SettingsContext context, SettingsPropertyCollection properties) at System.Configuration.SettingsBase.GetPropertiesFromProvider(SettingsProvider provider) at System.Configuration.SettingsBase.GetPropertyValueByName(String propertyName) at System.Configuration.SettingsBase.get_Item(String propertyName) at System.Configuration.ApplicationSettingsBase.GetPropertyValue(String propertyName) at System.Configuration.ApplicationSettingsBase.get_Item(String propertyName) at EOSUtility.AppSettings.get_FolderNameSeparator() at EOSUtility.RenamingService.RenamingFolder.updateFolderSeparator() at EOSUtility.RenamingService..ctor() at EOSUtility.RenameCountroller..ctor() at EOSUtility.MainMenu..ctor() at EOSUtility.Program.Main(String[] args)
12-10-2017 03:40 PM
I have the Rebel t3i. The EOS Utility was working fine with Window 10 Home until this latest round of updates. Now the computer is not recognizing the camera when I connect it using the USB cable. I have tried uninstalling and reinstalling the the EOS Utility and that did not help. When I manually start the EOS utiliy, it wants to connect to the camera via wifi, but this is not possible with my camera. Wish I could just tell is to use EOS Utility 2 instead of 3... Any suggestions?
02-11-2018 10:32 AM - edited 02-11-2018 10:34 AM
Hi, I'am from Ukraine, so first of all sorry for my bad English ))
I had same problem as rudibr
And I solved this problem.
Just remove all Canon aplications for your camera, download Canon CD old version 2.41 http://www.photoboothtechnology.com/download-eos-utility-full-version/ and install it, but DO NOT install any updates then.
So, you will have old version of EOS Utility, NOT EOS Utility 2
This old version doesn't crash on startup and works fine with my Canon 600D or Rebel T3i
Hope my advice will help someone.
