12-02-2024
10:46 AM
12:04 PM
Using an SD card to upload images from a T5 to a business FB page. With the card I was using specifically for our store, the images I just took to post would simply appear on the computer screen when I connected the camera to the computer. Then, I could select them and upload them easily. I used the camera for a wedding and used a different card for some images. Now, when I use the wedding card and connect the camera to the computer, I need to select the card and drill down to the images, find the images I want to use and select them. Is there some setting that I need to put into place for any card to work like my original card when I connect the T5 to the computer? I asked someone more tech savvy than I am but she could only help me find the images on the card from the wedding and then finding and selecting the images and inserting. The first card was so easy! Thanks for any help you can provide.
12-02-2024 11:01 AM
You don't say what computer, but I think that once you have used more than one card you will have this issue.
12-02-2024 01:10 PM - edited 12-02-2024 01:15 PM
Adding to kvbarkley's reply. 👍 In windows you can select the default behavior for Removeable Drives or Memory Cards. The feature is called Autoplay. >>>Settings > Devices > Autoplay.
These are your options
12-02-2024 04:51 PM
Thanks. I will give it a try and get back to you.
12-02-2024 04:53 PM
I’ll add it is a Windows machine. I think Lenovo. Can’t be upgraded to 11 so it’s a bit older.
12-02-2024 09:31 PM
Rick,
I tried these settings and they didn't resolve it. I'm going to get a new SD card and see what happens with that. Thanks for taking the time to reply. I appreciate it.
Sally
