08-25-2026 07:50 AM
Hi, per the topic title, in Canon Digital Photo Professional 4, when I have one or more images selected in a folder on my filesystem and I click on the "Tools" menu and then any number of the items there, such as "Start Compositing tool", "Start HDR compositing tool", "Start HDR PQ compositing tool", "Start Dual Pixel RAW Optimizer", etc, I get an error dialog popping up that simply says "Target file does not exist". I have searched online and cannot find any explanations as to what this error is referring to or means. AI has no clue and just starts hallucinating what it thinks are potential solutions, so that's a dead end.
All of my images were shot on a Canon EOS R6, all in RAW format (file extension is *.CR3), and my OS is Windows 10. I even tried moving some of the files to an NTFS volume, as my photo scratch volume runs ReFS, but that didn't change the outcome.
After some poking around, I did get the "Start HDR compositing tool" item to work, but only in a folder where I have non-HDR images stored, so it is kind of pointless there. It will not work in a folder on any images containing the "HDR" tag (I shot several using HDR PQ mode, so I have image triplets of +2, 0, and -2 exposure in this folder). I've tried adding the toolbar buttons for these as well, but no dice.
Has anyone figured out how to get these features to work? E.g., what are the necessary preconditions? I feel like this is a failure on Canon's part to actually do QA checks on their own software during development. This should be an easy bug to catch, unless the developers primarily work on non-Windows based development systems and don't bother to test Windows releases? If it is not a bug, then wtf am I missing, because it is incredibly non-obvious, whatever it is.
Thanks!
08-25-2026 02:16 PM
Did you try the non-PQ version of the tool?
08-25-2026 03:20 PM
If you mean "HDR compositing tool" in DPP, then yes, and it gives the same error if I have an HDR image selected. If I a normal, SDR image selected, it opens up a dialog for selecting up to three images to composite.
08-25-2026 03:35 PM
https://cam.start.canon/en/S002/manual/html/UG-05_Synthetic_0060.html
You can create PQ-compliant HDR images with less detail lost in highlights and shadows from three images that meet the following requirements.
Caution
Resulting HDR images have the following characteristics.
Note
