03-02-2026 10:15 AM - edited 03-02-2026 10:18 AM
Been trying to install DPP 4.20.11 or 4.21.10 but the installer starts and gets stuck without any progress. I need to reinstall after by my previous DPP version disappear from my menus.
Is there anyone having the same issue with a fix or workaround?
Thanks,
Guillermo
03-02-2026 10:28 AM - edited 03-02-2026 10:29 AM
Is this Windows or Mac? What's the version and build of your OS?
You mentioned having a previous copy. Do you have any third party antivirus installed that may block a software installation?
If you're running Windows, try using the Microsoft install on uninstall troubleshooter.
Fix problems that block programs from being installed or removed - Microsoft Support https://share.google/VcKtHQlNCfdDBVBN3
This was originally written for Windows 10, but it works under Windows 11 as well.
03-02-2026 12:01 PM
Thanks @Rick, this is on Windows 11. I do have antivirus and will double check but suspect that is not the issue. I'll the MS install/uninstall troubleshooter.
Guillermo
03-02-2026 12:08 PM
Sure. It's a handy utility that cleans up orphaned registry entries that can keep programs from uninstalling or reinstalling correctly.
03-04-2026 11:16 PM - edited 03-04-2026 11:27 PM
Hi Guillermo,
I just updated my DPP to the latest version 4.20.11 and it downloaded without a problem. FYI after the files have been downloaded, you'll need to close the utility or it will not install on your pc. Make sure you read all of the prompts / instructions that pop up and you shouldn't have any problems. The other thing that you can do is uninstall the app/program and reinstall as it will reinstall with the latest version. Let us know if that works by clicking the Solution icon.
03-05-2026 10:27 AM
Hi Joe, thanks for the reply. Nothing seems to be working on my side as far as the Canon installations. I'm still trying to figure things out.
Guillermo
