DPP batch incremental publish?
cebowler
Is there a way to have DPP only generate jpg for raws that have been edited since the last processing?  I'd like to have a way of knowing (in DPP) which photos have pending edits that need to force republishing and go ahead and process them.  Currently I need to regenerate an entire directory tree to ensure any pending updates are applied.
Waddizzle
I would suggest that you use the "Check Mark" feature to tag your files.  Use the "check marks" to identify how much progress you have made towards a finished output file.  The software allows you to filter/select files that have a specific "check mark" rating.
2 REPLIES 2
Waddizzle
cebowler
Fair enough as long as I remember to unset the checkmark when I re-edit an image.
