11-13-2019 08:47 AM
I use DPP on a daily basis. Nothing has changed on my computer since I ran it yesterday and everything was working fine. I have loaded it today and I have lost the folders from the left hand side. I cannot see anywhere to get this back.
Please can someone help?
Thanks,
Sam
12-13-2019 05:55 PM
11-13-2019 08:59 AM
On second look, I'm also missing the top bar which has the BATCH and other buttons.
11-13-2019 07:22 PM
Look for really teeny, tiny triangles along the edges of the borders of the user interface. If you see one, click it.
11-14-2019 02:17 AM
Hi there SamC123,
I agree with Waddizzle, it sounds like your window has switched to an expanded view of the central area but there should be small arrows on both the left and top sides that should show the expected information when clicked.
11-14-2019 03:03 AM
I know which triangles you mean as that was the first thing I looked for as I have in the past intentionally got rid of them so I can see more thumbnails. Alas, they are not there either top or left. Any other ideas?
11-14-2019 07:05 AM - edited 11-14-2019 07:06 AM
@SamC123 wrote:I know which triangles you mean as that was the first thing I looked for as I have in the past intentionally got rid of them so I can see more thumbnails. Alas, they are not there either top or left. Any other ideas?
You may try allowing your mouse to slowly hover and wander around in the area where the folder window and command ribbon would normally appear. Try to aim for the borders.
This should cause the missing ribbon and window to appear, along with the triangle to lock it in place.
11-14-2019 07:16 AM
11-14-2019 08:31 AM
If you've tried the above, and you're still having issues, you may want to reach out to support for one-on-one assistance. Our US-based team is at 1-800-OK-CANON (800-652-2666) weekdays from 9am to 9pm (ET).
If you're outside of the USA, please click HERE for support options in your country/region.
11-14-2019 05:30 PM
After Canon themselves being less than helpful, and much frustration, I decided to uninstall again, delete anything in the registry relating to Canon or DPP or Digital Photo Professional, restarted PC, then installed 4.11 again ... same problem. I then looked back into my old version zip files. Uninstalled 4.11, tried 4.10, same problem, then tried 4.9 ... YEY, IT WORKED! I have no idea why when I have been running 4.10 since the start of 2019 without problems until yesterday. Anyway, all fixed and needless to say I won't be installing an update for a while.
12-13-2019 05:52 PM
Your home screen got messed up. Simple fix. Go to your preferences under tools. If you're still having problems let me know and I'll give you more detailed instructions. Hopefully, you already got it fixed
