01-23-2026 08:45 AM
Good Morning!
I am using CRD to process clips from my Canon C500mkii. Clips are shot in RAW 5952x3140. I mostly film wildlife and scenics--so sharpness seems like a good idea.
What does increasing the sharpness actually do to a clip? Is it destructive or add noise? I've tested a clip imported at 0 and then also at 10 and there is a noticeable difference. But if I crank out all my clips at 10, have I done something that I'll regret down the line?
Thanks!
01-23-2026 12:45 PM - edited 01-23-2026 01:06 PM
When you increase the sharpening you are in reality adjusting the edge contrast on the entire image. If you over do the sharpening it will make the image look like a bad painting. Everything will have a very brittle look. A little bit goes a long way.😁
