05-18-2023 09:53 AM
please can someone tell me if I can use a sd card adapter on
05-21-2023 09:47 AM
Thanks for clarifying. This is not recommended. You will have issues.
05-18-2023 11:05 AM - edited 05-18-2023 11:09 AM
If you are referring to a card reader, the answer is yes.
If you are using a micro SD card with an adapter, then no, this is not recommended.
If the card is in a reader and cannot be read, try on another computer, if that fails, the card might be corrupt or has failed. You can try recovery software, or simply reformat the card. Note, reformatting the card will erase your photos and decrease your chances of recovery if that is what you want to do.
Reader
Adapter
05-21-2023 01:24 AM - edited 05-21-2023 01:27 AM
my question was if i can use the adapter instead of using SDHC or SDXC card directly?
05-21-2023 09:47 AM
05-22-2023 06:17 AM
thanks
