01-10-2024 07:58 PM
Can I use SD cards rated as UHS-1 in a camera that is compatible with UHS - 2 cards, or would I have to buy new memory cards?
Steve Thomas
01-10-2024 09:11 PM - edited 01-10-2024 09:16 PM
Hi Steve,
In some cases you might be able to get away with using a UHS-1 card in a UHS-2 slot. It might work for photos. Unless specified, I wouldn't do it
Here's where you can run into problems. High speed continuous shooting and video.
It's best to use cards rated for your body. I believe some body's do support both. In some cases, performance can only be guaranteed if you use a higher spec card.
Check your manual or specs. It will tell you which cards can be used and if there are any limitations.
01-10-2024 09:38 PM
Agreed. If your gear can work with UHS-II cards, they can have either double or triple the sustained write speed. That's the most important spec for cards. I believe UHS-I cards max out at V30 (30 MBps or 240 Mbps). Whereas UHS-II cards are available in V60 and V90 versions (for up to 90 MBps or 720 Mbps).
Even if using a V90 card, if RAW images average say 45 MB, you'd still fill up the camera's buffer if attempting to take a lot of continuous images. So if your camera can additionally work with CFexpress, that can really then give you very fast writes to much better continuous shooting.
01-10-2024 11:20 PM
You can use either one. Where the higher spec makes a difference is in high-speed continuous shooting or video. Faster write speeds of memory cards won't hold up shooting like a slower-to-write card can.
01-11-2024 04:57 AM
You certainly *can* use UHS-1 cards in a UHS-2 slot, or vice versa, and it will basically work. The card and camera will simply ignore the extra pins, and you will get UHS-1 performance.
But if your camera needs faster UHS-2 speeds -- e.g. for burst shooting, or for video shooting -- then you will need *both* ends of the connection to upport UHS-2 -- i.e the card and the camera. So yes, that means new cards.
01-11-2024 06:12 AM
Don’t try it. You won’t like it. Buy UHS-II memory cards, so that you do not lose data.
Will a UHS-I card work? Yes, but camera performance can and will be significantly degraded.
01-11-2024 07:52 AM
Thank you all.
That helps.
Moderators... Can I give an Accepted Solution to everyone? 😀
Steve Thomas
01-11-2024 07:57 AM
I believe you can (seen multiple accepted solutions on other topics). Though I don't know if there's any limit.
01-11-2024 08:37 AM
Theoretically, yes, though we tend to prefer that users limit themselves to just one per thread to keep things nice, neat, and concise. We recommended picking the one that best sums up the solution in a single post.
