10-29-2024 10:07 AM
I just bought a polarizing filter for my R7 kit lens. Are there special settings in the camera that I need in order to get it to work? As I rotate it, I can see the sky getting bluer through the viewer, but then it seems like the camera compensates, and the sky goes back to being washed out. I have it set to Spot Metering and AWB.
10-29-2024 10:37 AM
If you are just seeing this in the viewfinder, you might want to turn Exposure Sim off.
10-29-2024 10:25 AM
You probably need to have something else in the shot, and use evaluative metering. Also, don't use too wide of a lens.
10-29-2024 10:34 AM
Thanks. It was a landscape with both sky (1/3) and trees. I was using from 18-35mm. I will try evaluative metering.
10-29-2024 10:37 AM
10-29-2024 11:03 AM
For best results with a CPL filter, you want to remove it so that you can accurately set up your exposure and lock focus.
