04-24-2022 02:55 PM
I am new to photography. I live on the ocean. Most times in the morning, if the sea is flat, the small waves reflect the sunlight. It's an amazing view. I have been reluctant to take a photo because I would be shooting almost directly into the sun. I would like to filter out the direct sun without taking away from the wave sparkle.
Any suggestions are welcome.
04-24-2022 03:14 PM
Use the original filter: A hat to shade the sun.
04-24-2022 04:51 PM
Let me rephrase the question. Almost any suggestions are welcome.
04-24-2022 06:30 PM
Choose different angles such that you're not shooting directly into the sun. Also use a lens hood.
04-24-2022 07:45 PM
Good idea, but looking directly into the sun is what causes the reflection of the sun on the water. I need to block the sun without losing the reflection.
04-25-2022 08:40 AM
If the disk of the sun is in the camera frame, there is noting you can do. You need to angle the lens so that the sun is just out of the frame, and then use a hat. You could also find a friendly life guard tower or something to block the sun. You could also get a piece of paper or cloth and put it on a stand to put it directly between you and the sun.
Do NOT shoot or leave the camera for any period of time with the disk of the sun shining directly into the camera. Any number of bad things can happen.
04-25-2022 01:34 PM
I should probably have been more specific. I'm looking toward the sun not directly into it. The wave sparkle I'm trying to capture is an early morning reflection off the water. The sun is behind the clouds. The hat idea would work if the sun was overhead, but it's not. My vantage point is the 13th floor of a high rise a 1/2 mile from the ocean. It will take some experimentation but I'll figure it out.
04-25-2022 02:57 PM
The hat works fine for any angle where the disk of the sun is not directly in the image.
If the sun is behind the clouds, what is the issue?
04-25-2022 03:48 PM
If I could delete this thread I would. I never should have asked the question. I can't successfully describe what I am seeing.
04-25-2022 10:00 PM
Is the problem dynamic range? You can't expose for the sky and the water?
If so, you have two options.
One is to shoot HDR. Shoot multiple images at different exposures and combine them in post. (Or your camera may do this automagically). I suggest shooting at the exposure the camera says, then hold everything else the same and shoot a shutter speed 1/3 slower and another shot 3X faster. Then use HDR software to combine them.However, this may mush up the waves you are trying to capture.
The other way is old school. Get a gradient filter. This is a piece of glass with a dark top and clear bottom. It has a holder to let you adjust the dividing line up and down. In your case, put the dividing line right at the horizon and expose for the water. The dark half will darken the sky for you.
