Gimbal for Powershot SX740 HS??
Taylorxox1234
Does anyone know if there’s a gimbal that will work with the powershot sx740 hs?
4 REPLIES 4
Tronhard
VIP
VIP
Hi Taylor and welcome:
Given that the camera has a tripod mount screw at the bottom, conventional wisdom says you get an gimbal with a tripod screw or plate and that should work with your camera - you just screw in the plate or mount and it works.
Are you looking for gimbal especially for video work?  I will let my video centric associates address that...
cheers, TREVOR
To my knowledge, the SX740HS cannot be remotely controlled.
I suspected that, but appreciate your video knowledge.  Not sure if the OP wants to just take photos or a video but suspect the latter...
cheers, TREVOR
Thank you for responding. I have a gimbal now that works great for stabilizing but I can’t control the functions of the camera with it so that’s why I had asked if there possibly was one. If there isn’t it’s not the end of the world because I’m able to still remotely use my phone to control the camera functions while using the gimbal for stabilization.
