10-14-2024 09:16 AM - last edited on 10-15-2024 09:54 AM by Danny
I think this is the best solution on filters for all EF lens, don't know why canon haven't make an adapter between lens & body like EF-RF?
10-14-2024 09:34 AM
Because if you move the lens away from the body you lose infinity focus.
10-14-2024 11:53 AM
Seems canon ef-rf drop in works very well
10-14-2024 12:13 PM
Because the flange-to-sensor distance of the RF mount is less than the EF mount an EF - RF adapter has more room to work with.
Teleconverters have optics that can compensate, a drop-in filter adapter does not.
10-14-2024 10:34 AM - edited 10-15-2024 10:44 AM
"Because if you move the lens away from the body you lose infinity focus."
\Well if the lens was designed to use drop in filters it would work and not affect focus. However the reason for drop in filters is cost. There is not cost benefit for a lens that uses a smaller relatively cheaper front filter vs a very much more expensive drop in filter drawer and filter assembly.
Probably the most used and necessary filter in today's world is the polarizer. Using a drop in filter makes designing them and using them more complex and expensive. Add to that, the fact that most all filters are obsolete today.
10-14-2024 10:46 AM
He is talking about an adapter - much like a teleconverter - that you can place between *any* EF lens and the camera body to use drop in filters. So these lenses are specifically *not* designed for drop in filter use.
10-14-2024 11:11 AM
Oh, OK thanx, for the info. I will stick by this statement though, "Add to that, the fact that most all filters are obsolete today."
10-14-2024 11:36 AM
You can stick by that. 8^) I also am not sure why the OP wants a filter.
10-14-2024 12:27 PM - edited 10-14-2024 12:30 PM
Why want a filter, Are you joking?
For distance matter, I think Canon can do research on this optical physics problem
10-14-2024 05:04 PM
Depends what you're doing. For my typical photography, filters are VERY important.
No one is staying that everyone needs to use filters, but for some people they are indispensable.
