CF-R20EP battery grip with R5C
DJ_aa7
Since the cooling fan battery grip, cf-r20ep, intended for the R5 mark II also works with the older R5, will it also work with the R5C?
Or is the R5C stuck with only the BG-R10?
2 REPLIES 2
Good question.  The R5 C does not have the anti-twist pin slots like the R5 mkII, so the CF-R20EP would not fit. The CF-R20EP is designed to interface with the cooling vents on the bottom of the R5 mkII.  These do not exist on the R5 C.  The BG-R10 or the WFT-R10A are the only battery grip options on the R5 C.
And of course the R5C has its own cooling fan, in a big bulge under the display.
