Battery Pack LP-E6P compatibility with EOS R6 Mark II
justadude
Whiz
Whiz
Quick question on batteries... I need another backup battery for my R6 Mk ll, which I've been using the LP-E6NH, and an older LP-E6.  Called the local camera store to see if they had any of the Canon brand LP-E6NH in stock, and they told me they only had the LP-E6P, which is the new and improved replacement.
I had not heard of this battery yet, so I looked at B&H, which specifies that this battery is ONLY for the R5 Mk ll.  Went to Canon's web site to look, and it does not clarify that this is only for a specific camera.
Does anyone know if the LP-E6P will work in the R6 Mk ll?
Gary
Lake Michigan Area MI
Digital Cameras: Canon EOS R6 Mk ll, EOS R8, EOS RP, ...and a few other brands
Film Cameras: Mostly Pentax, Kodak, and Zenit... and still heavily used
Tronhard
VIP
VIP
There is a firmware update out for a bunch of cameras, including the R6II that allows it to use the new LP-E6P, so download that and you can use the new batteries.
Firmware Notice: EOS R6 Mark II: Firmware Version 1.5.0 | Canon U.S.A., Inc.
As per the description of the update:
1. Enables functions to be used without limitation in conjunction with the new Battery Pack LP-E6P. This makes it possible to shoot at the same continuous shooting speed as when using LP-E6NH. In-camera charging of LP-E6P is also supported.
cheers, TREVOR
2 REPLIES 2
Tronhard
VIP
VIP
cheers, TREVOR
Thank you, Trevor!  I was unaware that 1.5.0 was out, so of course I didn't look at the updates included. I'm still on version 1.4.0.
Since this is a firmware update, and I have a hired marathon event to shoot this weekend, something tells me to wait until Monday to update the firmware, just to be safe.  I've always had good luck updating firmware, but with my luck this would be the first time I would have a problem with it freezing up since it is right before a hired event - lol.
Gary
