05-01-2020 01:20 AM
05-01-2020 08:36 AM
Hi busler62,
To get a live video feed from the camcorder you will need to use the HDMI connection instead of USB. Another common road block when beginning to live stream is that the HDMI port on most computers is designed for output only which would mean that it can output onto an external monitor, it does not accept an HDMI input signal from another device. If your computer does not accept an HDMI input signal then a separate piece of hardware called a capture card would be necessary to adapt your computer to work with HDMI input.
