07-11-2020 05:09 AM
I would like to erase the previous recording on a DVD tape on my Canon Optura 50 and use tape again. Will a new
recording erase the previous recording?
Thanks
07-11-2020 11:23 AM
Your camera will not delete or overwrite recorded footage unless told to do so. Reading your product's manual will likely help answer your question. Page 32.
http://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDkwMDAwMDY4MjAx&cmp=ABR&lang=EN
07-11-2020 02:49 PM
Thanks for your reply and information. I have searched through the manual about this but not found instructions how to erase the tape. I did look at page 32 and maybe I am just not seeing or understanding it.
07-12-2020 12:57 AM
Hi no1texan,
Thanks for the reply.
You won't be able to erase a Mini DV tape in the way that you can erase or format a memory card, but you can record over the prior footage. Simply rewind the tape to the area where you want to start recording, switch back to the camera mode, and press record.
Hope that helps.
