LEGRIA HF R506 LCD screen only works when facing forward
Adamw1
EDIT: Issue solved. I opened up the camera and noticed 2 things:
The open/closed switch was stuck
The screen orientation magnet fell out of place
After moving the switch for a little bit and putting the magnet back in the pocket, the camera functions normally.
Post:
I have a flipscreen problem with my camcorder (Legria HF R506). When the screen is open, it is completely black, as if it was off. When face it forward (facing with the lens), it turns back on, which seems like some sort of "screen open/closed" sensor malfunction. I have tried changing different settings such as "Auto power off" or "Power On Using LCD Panel". It didn't work, so I reset it back to factory settings.
Pictures for reference:
As you can see above, the LCD doesn't work when open, even though the camcorder is on. 
And it does when it is flipped around.
If you know how to solve this issue, please share your thoughts.
2 REPLIES 2
Arthur
Moderator
Moderator
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
normadel
It's a ten-year-old camera with bad contacts or cable connecting the display to the body. It happens. It needs servicing, if there's anyone out there who can/will do it. Likely not Canon.
